We use the label component to represent conveyors, in essence the color is changed to represent the conveyor state. The following is an issue I am seeing. I have tested this in 8.1.13 and 8.1.16.
When we have a conveyor in a coordinate view horizontally, it can be moved all the way to the edge of the view and not until it crosses the edge does a scroll bar appear, as follows:
At the edge but not yet over
Across the edge a scroll bar appears as expected
However, when the label is rotated 90 degrees, it causes a scroll bar even when it is not pressed up against the edge. It is as if the label still take the horizontal space it did in the above photos.
Even when not against the edge, a scroll bar appears
What want is to be able to push it right up against the edge if needed without having the scroll bar appear. Note that we have to use coordinate containers to do conveyor layouts.
Is there any work around for this?
Thanks,
Nick
