I am using Ignition Platform 8.1.40, and am having an issue with mapping transform from a page parameter. In the View, I have the parameter labeled "Slot". This is working fine for indirect addressing of tags. This also works fine if it is directly used in the text of a label. If I try to do a mapping transform, everything looks fine in Designer, but not in the browser. In the browser it is going to the fallback transform, and not the one that matches the parameter "Slot". The "Slot" parameter value is being set to "3", so I believe it should be displaying correctly. Is there something that I am missing?
The Edit Binding window is from designer, and below where it says "Fallback" is in the browser.
