Label on Moving Analog Indicator Getting Cutoff in Perspective
Hi All,
Is there any way I can prevent the last digit on the moving analog indicator label from getting cuttoff like it is in the screenshot? Any label parameters I can tweak?
Thanks,
Greg
The label has a style prop where you can set the font size. Doesn’t look like the margin/padding settings have any effect, so I think font size is your best bet
I am also having this issue with the moving analog indicator in vertical mode. Perhaps an offset property for the label like the axis labels in the Power Chart?
Go to label style properties under "misc." and make overflow visible
