Language Translation for each node in Tree View
Hi, I am using the Tree view
I want to translate the words in Tree view to French
This is expand of folder in treeview
whether i should have this format in translation manager or each word added in translation will be translate?
can anyone let me know
You will need to translate the dataset you supply to the tree view. (Using scripting or an expression function are easy ways to do that as you build the dataset.) The translation manager looks for entire strings as matches, but scripting may allow you to translate individual words as you build the path.
