Well… I finally did it. I found something I couldn’t do in Ignition… at least not yet. A sad day…
I ran into the apparent 65536 byte script size limitation using v7.2.11.
Traceback (innermost last):
(no code object) at line 0
java.lang.VerifyError: (class: org/python/pycode/_pyx2, method: f$0 signature: (Lorg/python/core/PyFrame;)Lorg/python/core/PyObject;) Incompatible object argument for function call
Well, the actual script size is about 35k, but by the time it compiles, I’m hosed.
Yes, I can make my script a bit smaller, possibly enough to squeeze it into the limitation. But the big picture is that this script is only about a third of the functionality of the overall script.
In keeping with the big picture, it’s not a big deal as I can still use standard python to get what I want done. It just would have been nice to store as a gateway script.
I think the limitation was raised a bit as of Jython 2.5, but haven’t found any hard evidence of it.
Can you break the script up into smaller function calls that are written in another scripting module?
