“Launch client jar signature is invalid” 8.1.51
I have this error "Launch client jar invalid" "This launch client jar signature is invalid. Contact an administrator."
I have seen the other threads and they are not my issue, I have tried all of those solutions.
This is an Intune Windows Machine. I have this working on another machine exactly the same and I cannot remember how. Is anyone able to help me out here ?
Click to view full Java exception log
INFO  [GatewayCommUtil               ] [2026/10/30 09:02:29]: Downloading "http://my.company.webaddress/system/launchbin/launchclient.jar" (timeout=30)...
INFO  [GatewayCommUtil               ] [2026/10/30 09:02:29]: Starting download of 6844145 bytes
ERROR [LaunchClientJarService        ] [2026/10/30 09:02:30]: Launch client jar Invalid
java.net.SocketException: Connection reset
	at java.base/sun.nio.ch.NioSocketImpl.implRead(NioSocketImpl.java:328)
	at java.base/sun.nio.ch.NioSocketImpl.read(NioSocketImpl.java:355)
	at java.base/sun.nio.ch.NioSocketImpl$1.read(NioSocketImpl.java:808)
	at java.base/java.net.Socket$SocketInputStream.read(Socket.java:976)
	at java.base/java.io.BufferedInputStream.read1(BufferedInputStream.java:282)
	at java.base/java.io.BufferedInputStream.read(BufferedInputStream.java:343)
	at java.base/sun.net.www.MeteredStream.read(MeteredStream.java:141)
	at java.base/java.io.FilterInputStream.read(FilterInputStream.java:132)
	at java.base/sun.net.www.protocol.http.HttpURLConnection$HttpInputStream.read(HttpURLConnection.java:3763)
	at com.inductiveautomation.ignition.launcher.common.utils.Crc32InputStream.read(Crc32InputStream.java:32)
	at java.base/java.io.FilterInputStream.read(FilterInputStream.java:106)
	at com.inductiveautomation.ignition.launcher.common.utils.GatewayCommUtil.downloadFile(GatewayCommUtil.java:584)
	at com.inductiveautomation.ignition.launcher.common.service.LaunchClientJarService$LaunchClientJarTask.lambda$downloadLaunchClientJar$3(LaunchClientJarService.java:362)
	at com.inductiveautomation.ignition.launcher.common.utils.FileUtils.runResourceLockedAction(FileUtils.java:110)
	at com.inductiveautomation.ignition.launcher.common.service.LaunchClientJarService$LaunchClientJarTask.downloadLaunchClientJar(LaunchClientJarService.java:360)
	at com.inductiveautomation.ignition.launcher.common.service.LaunchClientJarService$LaunchClientJarTask.getLaunchClientJar(LaunchClientJarService.java:227)
	at com.inductiveautomation.ignition.launcher.common.service.LaunchClientJarService$LaunchClientJarTask.call(LaunchClientJarService.java:167)
	at com.inductiveautomation.ignition.launcher.common.service.LaunchClientJarService$LaunchClientJarTask.call(LaunchClientJarService.java:139)
	at javafx.concurrent.Task$TaskCallable.call(Task.java:1426)
	at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
	at javafx.concurrent.Service.lambda$executeTask$6(Service.java:728)
	at java.base/java.security.AccessController.doPrivileged(AccessController.java:399)
	at javafx.concurrent.Service.lambda$executeTask$7(Service.java:727)
	at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1136)
	at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:635)
	at java.base/java.lang.Thread.run(Thread.java:840)
That is an interrupted jar download. Typically anti-virus or similar anti-malware. Sorry, but this is induced outside Ignition.
Yeah, I had been down that track, it actually did come from ignition in the end last time. The log is not much use at all.
Its got something to do with ignition not liking the way the Intune PC's work. I had to change a setting in the config. But of course, I did not record my findings last time and now I am hoping someone has had a similar issue.
Maybe, but it wouldn't have been that error message. Connection Reset is a network error, typically from a firewall or anti-malware install.
Yeah, unfortunately it was the same error.
I went down the firewall / security track last time and this time. Its not being blocked. Even tried to get it blocked by the firewall a number of ways. there is no events showing it was blocked. Just stopped traffic for no reason.
I have gotten around it for now. but if anyone has the same issue. please let me know.
The setting you're probably thinking of is signature.verification.strength in %USERPROFILE%\.ignition\clientlauncher-data\vision-client-launcher.json. Setting it to LENIENT lets an 8.3 launcher (default MODERATE) launch against Gateways older than 8.1.34, whose launchclient.jar isn't signed. Details: Launchers and Workstation | Ignition User Manual
That isn't what's happening here, though. Your Gateway is 8.1.51, so its jar is signed and would verify at any strength. And your log shows the download of launchclient.jar being reset about a second in, before signature verification even runs. The launcher shows that same "signature is invalid" dialog for any failure getting or checking the jar, so the message is misleading in your case. The jar never fully arrived.
This is external to Ignition, and there's not really any room for dispute.
No that wasnt it no.
