Hello Guys,
I can not start Lunch Designer and I get the following error:
“Error launching application; httpresponseexception:500 internal server error”
I can start Lunch Designer only after restart the server(gateway).
Do you guys have any ideea about this problem?
Thank you in advance!!
There would be something in the wrapper log for such errors.
Hello,
Yes, indeed there are errors.
Can you help me interpret these errors?
pturmel
October 31, 2020, 12:30pm
4
Not from a screen shot. Please open the wrapper log itself and copy the actual (complete) text of those errors and paste them here. Be sure to use the “preformat” button ( </> ) to make it neat.
pturmel
October 31, 2020, 12:32pm
5
But not those errors–those are device communication problems, not a launch problem. Look for something that shows up at the same time as your server error.
INFO | jvm 1 | 2020/11/09 14:53:42 | W [d.M.ReadHoldingRegistersRequest] [12:53:42]: Request failed. FailureType==DISCONNECTED device-name=PT109
INFO | jvm 1 | 2020/11/09 14:53:42 | java.lang.Exception: RequestCycle stopped.
INFO | jvm 1 | 2020/11/09 14:53:42 | at com.inductiveautomation.xopc.driver.api.BasicRequestCycle.shutdown(BasicRequestCycle.java:281)
INFO | jvm 1 | 2020/11/09 14:53:42 | at com.inductiveautomation.xopc.driver.api.AbstractDriver.createNewRequestCycle(AbstractDriver.java:736)
INFO | jvm 1 | 2020/11/09 14:53:42 | at com.inductiveautomation.xopc.driver.api.AbstractDriver.notifyDisconnectDone(AbstractDriver.java:695)
INFO | jvm 1 | 2020/11/09 14:53:42 | at com.inductiveautomation.xopc.driver.api.AbstractIODelegatingDriver.notifyDisconnectDone(AbstractIODelegatingDriver.java:71)
INFO | jvm 1 | 2020/11/09 14:53:42 | at com.inductiveautomation.xopc.driver.api.AbstractIODelegatingDriver.disconnect(AbstractIODelegatingDriver.java:43)
INFO | jvm 1 | 2020/11/09 14:53:42 | at com.inductiveautomation.xopc.driver.api.AbstractIODelegatingDriver.reconnect(AbstractIODelegatingDriver.java:93)
INFO | jvm 1 | 2020/11/09 14:53:42 | at com.inductiveautomation.xopc.drivers.modbus2.AbstractModbusDriver.access$100(AbstractModbusDriver.java:91)
INFO | jvm 1 | 2020/11/09 14:53:42 | at com.inductiveautomation.xopc.drivers.modbus2.AbstractModbusDriver$2.notifyCommunicationTimeout(AbstractModbusDriver.java:132)
INFO | jvm 1 | 2020/11/09 14:53:42 | at com.inductiveautomation.xopc.drivers.modbus2.requests.AbstractModbusRequest.fail(AbstractModbusRequest.java:169)
INFO | jvm 1 | 2020/11/09 14:53:42 | at com.inductiveautomation.xopc.drivers.modbus2.requests.AbstractModbusReadRequest.fail(AbstractModbusReadRequest.java:121)
INFO | jvm 1 | 2020/11/09 14:53:42 | at com.inductiveautomation.xopc.driver.api.ScheduledRequest.fail(ScheduledRequest.java:124)
INFO | jvm 1 | 2020/11/09 14:53:42 | at com.inductiveautomation.xopc.driver.api.BasicRequestCycle$TimeoutDaemon.failRequests(BasicRequestCycle.java:371)
INFO | jvm 1 | 2020/11/09 14:53:42 | at com.inductiveautomation.xopc.driver.api.BasicRequestCycle$TimeoutDaemon.run(BasicRequestCycle.java:327)
INFO | jvm 1 | 2020/11/09 14:53:42 | at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
INFO | jvm 1 | 2020/11/09 14:53:42 | at java.util.concurrent.FutureTask.runAndReset(Unknown Source)
INFO | jvm 1 | 2020/11/09 14:53:42 | at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(Unknown Source)
INFO | jvm 1 | 2020/11/09 14:53:42 | at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)
INFO | jvm 1 | 2020/11/09 14:53:42 | at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
INFO | jvm 1 | 2020/11/09 14:53:42 | at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
INFO | jvm 1 | 2020/11/09 14:53:42 | at java.lang.Thread.run(Unknown Source)
INFO | jvm 1 | 2020/11/09 14:53:42 | W [d.M.ReadHoldingRegistersRequest] [12:53:42]: Request failed. FailureType==DISCONNECTED device-name=PT705
INFO | jvm 1 | 2020/11/09 14:53:42 | E [d.M.ReadHoldingRegistersRequest] [12:53:42]: Received response with ExceptionCode: 0x02 (IllegalDataAddress). device-name=PT737
INFO | jvm 1 | 2020/11/09 14:53:42 | E [d.M.ReadHoldingRegistersRequest] [12:53:42]: Received response with ExceptionCode: 0x02 (IllegalDataAddress). device-name=PT730
INFO | jvm 1 | 2020/11/09 14:53:42 | E [d.M.ReadHoldingRegistersRequest] [12:53:42]: Received response with ExceptionCode: 0x02 (IllegalDataAddress). device-name=PT733
INFO | jvm 1 | 2020/11/09 14:53:42 | W [d.M.ReadHoldingRegistersRequest] [12:53:42]: Request failed. FailureType==DISCONNECTED device-name=PT100
INFO | jvm 1 | 2020/11/09 14:53:42 | java.lang.Exception: Driver is disconnected.
INFO | jvm 1 | 2020/11/09 14:53:42 | at com.inductiveautomation.xopc.driver.api.AbstractDriver$RequestSchedule.cancelCurrentSchedule(AbstractDriver.java:1377)
INFO | jvm 1 | 2020/11/09 14:53:42 | at com.inductiveautomation.xopc.driver.api.AbstractDriver.notifyDisconnectDone(AbstractDriver.java:694)
INFO | jvm 1 | 2020/11/09 14:53:42 | at com.inductiveautomation.xopc.driver.api.BasicRequestCycle.shutdown(BasicRequestCycle.java:268)
INFO | jvm 1 | 2020/11/09 14:53:43 | W [d.M.B.TimeoutDaemon ] [12:53:42]: ScheduledRequest[com.inductiveautomation.xopc.drivers.modbus2.requests.ReadHoldingRegistersRequest@75bd84ea] request with key "java.lang.Object@46beacbe" failed due to timeout. device-name=PT215
INFO | jvm 1 | 2020/11/09 14:53:43 | W [d.M.ReadHoldingRegistersRequest] [12:53:42]: Request failed. FailureType==TIMEOUT device-name=PT215
INFO | jvm 1 | 2020/11/09 14:53:43 | java.lang.Exception: Request failed by TimeoutDaemon due to timeout: ScheduledRequest[com.inductiveautomation.xopc.drivers.modbus2.requests.ReadHoldingRegistersRequest@75bd84ea]
INFO | jvm 1 | 2020/11/09 14:53:43 | at com.inductiveautomation.xopc.driver.api.BasicRequestCycle$TimeoutDaemon.failRequests(BasicRequestCycle.java:374)
INFO | jvm 1 | 2020/11/09 14:53:43 | at com.inductiveautomation.xopc.driver.api.BasicRequestCycle$TimeoutDaemon.run(BasicRequestCycle.java:327)
INFO | jvm 1 | 2020/11/09 14:53:43 | at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
INFO | jvm 1 | 2020/11/09 14:53:43 | at java.util.concurrent.FutureTask.runAndReset(Unknown Source)
INFO | jvm 1 | 2020/11/09 14:53:43 | at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(Unknown Source)
INFO | jvm 1 | 2020/11/09 14:53:43 | at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)
INFO | jvm 1 | 2020/11/09 14:53:43 | at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
INFO | jvm 1 | 2020/11/09 14:53:43 | at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
INFO | jvm 1 | 2020/11/09 14:53:43 | at java.lang.Thread.run(Unknown Source)
INFO | jvm 1 | 2020/11/09 14:53:43 | Exception in thread "modbus-async-serial-io" java.lang.NullPointerException
INFO | jvm 1 | 2020/11/09 14:53:43 | E [d.M.ReadHoldingRegistersRequest] [12:53:43]: Uncaught Throwable handling response. key=java.lang.Object@46beacbe, req=[ ], rsp=[ ED 01 03 80 01 AC 02 99 ] device-name=PT411
INFO | jvm 1 | 2020/11/09 14:53:43 | java.lang.ArrayIndexOutOfBoundsException: null
INFO | jvm 1 | 2020/11/09 14:53:43 | W [d.M.B.TimeoutDaemon ] [12:53:43]: ScheduledRequest[com.inductiveautomation.xopc.drivers.modbus2.requests.ReadHoldingRegistersRequest@29a8d164] request with key "java.lang.Object@46beacbe" failed due to timeout. device-name=PT806
INFO | jvm 1 | 2020/11/09 14:53:43 | W [d.M.ReadHoldingRegistersRequest] [12:53:43]: Request failed. FailureType==TIMEOUT device-name=PT806
INFO | jvm 1 | 2020/11/09 14:53:43 | java.lang.Exception: Request failed by TimeoutDaemon due to timeout: ScheduledRequest[com.inductiveautomation.xopc.drivers.modbus2.requests.ReadHoldingRegistersRequest@29a8d164]
INFO | jvm 1 | 2020/11/09 14:53:45 | W [d.M.B.TimeoutDaemon ] [12:53:45]: ScheduledRequest[com.inductiveautomation.xopc.drivers.modbus2.requests.ReadHoldingRegistersRequest@29a8d164] request with key "java.lang.Object@46beacbe" failed due to timeout. device-name=PT806
INFO | jvm 1 | 2020/11/09 14:53:45 | W [d.M.ReadHoldingRegistersRequest] [12:53:45]: Request failed. FailureType==TIMEOUT device-name=PT806
INFO | jvm 1 | 2020/11/09 14:53:45 | java.lang.Exception: Request failed by TimeoutDaemon due to timeout: ScheduledRequest[com.inductiveautomation.xopc.drivers.modbus2.requests.ReadHoldingRegistersRequest@29a8d164]
INFO | jvm 1 | 2020/11/09 14:53:45 | at com.inductiveautomation.xopc.driver.api.BasicRequestCycle$TimeoutDaemon.failRequests(BasicRequestCycle.java:374)
INFO | jvm 1 | 2020/11/09 14:53:45 | at com.inductiveautomation.xopc.driver.api.BasicRequestCycle$TimeoutDaemon.run(BasicRequestCycle.java:327)
INFO | jvm 1 | 2020/11/09 14:53:45 | at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
INFO | jvm 1 | 2020/11/09 14:53:45 | at java.util.concurrent.FutureTask.runAndReset(Unknown Source)
INFO | jvm 1 | 2020/11/09 14:53:45 | at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(Unknown Source)
INFO | jvm 1 | 2020/11/09 14:53:45 | at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)
INFO | jvm 1 | 2020/11/09 14:53:45 | at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
INFO | jvm 1 | 2020/11/09 14:53:45 | at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
INFO | jvm 1 | 2020/11/09 14:53:45 | at java.lang.Thread.run(Unknown Source)
Hello Guys,
In addition to this error, I noticed in the gateway status that there is no storage space on the server, although in reality there is no such problem. After restarting the gateway service, none of these errors exist. The Wrapper log file is too large to copy all those errors.
I initialized luch designer at 14:53:43.
Can you help me with these errors?
