Hello,
I am running into an issue after installing a brand new Ignition instance on a server that is throwing an extremely long error code:
I have tried clearing my cache folder, deleting the cache folder, deleting the .ignition folder, and uninstalling/reinstalling the designer launcher.
This is for ignition version 8.1.48, and if you're curious what the design launcher log error is, here it is:
Launch Error Occurred: Java process launch failed with error code 1: fs.WindowsException.rethrowAsIOException(WindowsException.java:108)
at java.base/sun.nio.fs.WindowsFileAttributeViews$Basic.readAttributes(WindowsFileAttributeViews.java:53)
at java.base/sun.nio.fs.WindowsFileAttributeViews$Basic.readAttributes(WindowsFileAttributeViews.java:38)
at java.base/sun.nio.fs.WindowsFileSystemProvider.readAttributes(WindowsFileSystemProvider.java:199)
at java.base/java.nio.file.Files.readAttributes(Files.java:1851)
at java.base/java.util.zip.ZipFile$Source.get(ZipFile.java:1457)
at java.base/java.util.zip.ZipFile$CleanableResource.<init>(ZipFile.java:726)
at java.base/java.util.zip.ZipFile.<init>(ZipFile.java:260)
at java.base/java.util.zip.ZipFile.<init>(ZipFile.java:189)
at java.base/java.util.jar.JarFile.<init>(JarFile.java:346)
at java.base/sun.net.www.protocol.jar.URLJarFile.<init>(URLJarFile.java:103)
at java.base/sun.net.www.protocol.jar.URLJarFile.getJarFile(URLJarFile.java:72)
at java.base/sun.net.www.protocol.jar.JarFileFactory.getOrCreate(JarFileFactory.java:106)
at java.base/sun.net.www.protocol.jar.JarURLConnection.connect(JarURLConnection.java:132)
at java.base/sun.net.www.protocol.jar.JarURLConnection.getInputStream(JarURLConnection.java:175)
at java.base/java.util.ResourceBundle$Control$2.run(ResourceBundle.java:3237)
at java.base/java.util.ResourceBundle$Control$2.run(ResourceBundle.java:3226)
at java.base/java.security.AccessController.doPrivileged(AccessController.java:569)
at java.base/java.util.ResourceBundle$Control.newBundle0(ResourceBundle.java:3225)
at java.base/java.util.ResourceBundle$Control.newBundle(ResourceBundle.java:3151)
at java.base/java.util.ResourceBundle.loadBundle(ResourceBundle.java:1984)
at java.base/java.util.ResourceBundle.findBundle(ResourceBundle.java:1770)
at java.base/java.util.ResourceBundle.findBundle(ResourceBundle.java:1722)
at java.base/java.util.ResourceBundle.getBundleImpl(ResourceBundle.java:1656)
... 5 more
Any help would be greatly appreciated!
