Hi Team ,
I want to create Launcher configuration Zip folder to install launchers with unique configuration.
When i follow standard ignition manual its mentioned about clientlauncher-data Folder which i can't able to find in my Inductive Automation(Installed Folder).
whether it will be installed by default and we need to configure? or need to created separately if so what is the procedure or any reference document?
It is placed in the user's home .ignition folder by default. It is not a system-wide folder.
but for me its not installed during installation do i need to re install ignition?
Installing Ignition installs just the gateway. Installing launchers happens where you need them, typically not the gateway. Each launcher installed separately has its own configuration.
