Hi all
I have configured the use of active directory using LDAP in the gateway.
I can see the list of active directory users and the test authentication process is working fine.
However when i run the client the authentication fails…
The gateway log starts as following…
java.lang.Exception: Authentication using username and password is required.
at com.inductiveautomation.ignition.gateway.authentication.impl.InternalUserSource.authenticate(InternalUserSource.java:152)
at com.inductiveautomation.ignition.gateway.authentication.UserSourceWrapper.authenticate(UserSourceWrapper.java:200)
at com.inductiveautomation.ignition.gateway.servlets.gateway.functions.Login.client(Login.java:120)
- I am logging in thru the client using the format : domainName\username
what am I doing wrong ?
thanks and regards
Dominic
