We have a bunch of properties in a Perspective view which all have bindings that run a nearly identical script. Properties look like this in Designer:
All of those bindings have a script in them that just calls the same function with one changed parameter that gives the name of the property it is bound to. So, the binding on AlarmEnabled calls
doFoo('AlarmEnabled',x,y,z)
while the one on AlarmMode calls
doFoo('AlarmMode',x,y,z)
Is there any way that the binding transform script could find the full or partial property path for the property it is attached to? It's a simple thing, but could save me a lot of time copy-paste-editing bindings. Same with onChange scripts as well: there's no way to find the name of the property that is attached to, and I have to do similar copy-paste-edit work often.
