i don't know anything about ignition apart from how to install it and what it can do. It looks so complex especially that you need to open an application, a website and some other thing i don't know. Its tutorials aren't really in depth. Can a good Samaritan please help.
Are you talking about the inductive university (which you should absolutely start with) which has over 40hrs of content?
But to elaborate slightly on your initial confusion, you configure the server/gateway from the web portal (think users, plc connections, tag providers, historian connections, security setup, and you configure and design projects which run in the gateway (think the graphics, scripts, configuration of tags - they don't contain the tags though as these are gateway resources, alarm notification pipelines, reports, etc) , from the separate Designer application which you install and runs locally.
You can use the Ignition user manual if the tutorials don't cover everything you need.
Thank you so much. Let me finish inductive university then I'll get back to you
