When displaying a value in numeric mode, the LED Display does not render properly at runtime in Vision. It does display correctly in Designer.
FYI this is an intermittent issue. Works sometimes, doesn’t work others.
Can you be more specific on what you mean by
Does not render properly
I would suspect this is a binding related issue, similar to your other post, but it’s hard to say for sure.
Perhaps but still exhibited inconsistent rendering b/n designer and runtime and occasionally renders without any decimal places.
I’ve tried changing the number formatting (example getting rid of commas/periods) which will work fine in Designer, but in the client the changes are not reflected.
