Quick question, is it possible to use a LIKE wildcard in a named query? If so how do you do it?
I would pass the entire pattern of the LIKE as a parameter.
Thats what I was afraid of, I have made a called template that has a StringInput property that is used in several places in my project. For my name query I am just handing it the StringInput value. Any suggestions of how to deal with that?
Use your DB’s concat function to construct the complete pattern from the static part and your string parameter.
Ah, thank you very much.
Ok, so I got the concat to function like I wanted but I am having an issue with the filtering. Here is my code:
SELECT
HangerNumber,
Room,
PartNumber,
PartDescription,
WorkOrder,
Customer,
RecipeNumber,
CoatNumber,
RobotProgram,
EventDescription,
Temperature,
Humidity,
Weight,
TimeStamp,
Username
FROM
event_history
WHERE
((TimeStamp >= :StartTime) AND (TimeStamp <= :EndTime)) AND
((PartNumber LIKE concat(:PartNumber, '%')) OR
(0 = :PartNumber)) AND
((WorkOrder LIKE concat(:WorkOrder, '%')) OR (0 = :WorkOrder)) AND
((PartDescription = concat('"':PartDescription, '%"')) OR (0 = :PartDescription)) AND
((Customer LIKE concat(:Customer, '%')) OR (0 = :Customer))
The filters work when the data only includes numbers but wont filter if that are letters in any of the cells. Have any idea what I am doing wrong?
