So I accidentally typed a period instead of a comma when addressing a Siemens PLC. I quickly realized the error and immediate fixed the issue.However, my gateway logs are spammed with this error thousands of times per minute and I cant do anything to fix it since nothing is even using the address that is causing the error. Gateway logs are pretty useless unless you know what you need to filter.
