Today I just noticed I have several PC’s logged into an Ignition project all with the same username. Is there a way (v7.8.2) to limit each username or a username to only login once??
You can do it with a client startup event script and a message handler script. Call the getSessionInfo() function to obtain all users, iterate through it comparing user names to the logged in user and clientId, and then sending a suicide message to the clients that are duplicates.
Hi
Has this functiomality been implemented in the newer versions? or do you still need to manually code it?
Thanks in advance
Hi @efernandezmorgan may I know that do you find the solution to solve this problems ?
Thanks in advance.
