Limitation on using embedded view in map layers.ui.view
Hi
When I use any embedded view with width and height other than 64x64 px for perspective map component (layers.ui.view), I see the result render blurry and when change the zoom it coordinate change and has some offset from its original lat, lng setpoint.
I wonder why this is happened. Is there any limitation for defining view size for map?
