I am using Ignition 7.6.3 onward and I would like to write an INSERT query every time a tag changes.
I can do this without the Alarm notification module, correct?
Try using the Gateway Tag Change event scripts.
Can’t I use the alarming right on the SQLtags and trigger an expression to write a query?
something like this:
Hey,
No, the first suggestion for a tag change script would be the way to go. What you’re doing with the alarm is not really going to work like you expect. That is going to be executed any time the alarm data is “captured”, which will be multiple times per alarm.
Regards,
