Hi
Is there a Maximum number of rows ( or other limits to know) with python script?
I created a script inside a button in the event of “actionperformed” ( 1055 rows) , everything worked correctly, but after a small modification, I cannot save anymore the script.
I have always the following Java error:
anyone can give me a suggestion
Thank you very much!
Andrea
[i]
Parse error for event handler “actionPerformed”
java.lang.NullPointerException
at org.python.objectweb.asm.MethodWriter.b(Unknown Source)
at org.python.objectweb.asm.MethodWriter.d(Unknown Source)
at org.python.objectweb.asm.MethodWriter.a(Unknown Source)
at org.python.objectweb.asm.ClassWriter.toByteArray(Unknown Source)
at org.python.compiler.ClassFile.write(ClassFile.java:124)
at org.python.compiler.Module.write(Module.java:613)
at org.python.compiler.Module.compile(Module.java:669)
at org.python.compiler.Module.compile(Module.java:648)
at org.python.compiler.LegacyCompiler$LazyLegacyBundle.ostream(LegacyCompiler.java:64)
at org.python.compiler.LegacyCompiler$LazyLegacyBundle.saveCode(LegacyCompiler.java:58)
at org.python.core.CompilerFacade.compile(CompilerFacade.java:33)
at org.python.core.Py.compile_flags(Py.java:1717)
at org.python.core.Py.compile_flags(Py.java:1722)
at org.python.core.Py.compile_flags(Py.java:1752)
at com.inductiveautomation.factorypmi.designer.eventhandling.ComponentScriptEditor.applyChanges(ComponentScriptEditor.java:518)
at com.inductiveautomation.factorypmi.designer.eventhandling.ComponentScriptEditor.access$600(ComponentScriptEditor.java:87)
at com.inductiveautomation.factorypmi.designer.eventhandling.ComponentScriptEditor$5.actionPerformed(ComponentScriptEditor.java:342)
at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.access$500(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(Unknown Source)
at java.awt.EventQueue$4.run(Unknown Source)
java.lang.NullPointerException: java.lang.NullPointerExceptio[/i]
