Line break in expression tag?
Hi i have trying to use the mousover cursor property value of an image to display 2 values using expressing binding as shown below. I want to do a line break between the two. i used '\n' but that doesnt seem to work. any ideas?
You could try starting with <html> and adding <br> where you want your line breaks.
Can you give an example?
Result:
Html line breaks work on most Vision components with text properties. What component are you displaying this on?
The thing to try when html doesn't work is \n
I just want to put a mouseover with the values of two tags, but with a line break.
Example:
Rack = 1
Voltage = 1.4
I understand that the text properties are interpreted in the same way as the Mouseover Text properties
I tested it on the mouseover text of a button, and it works for me.
Test Expression:
Property Editor:
Result:
omg sorry, I was seeing the result only in the vision propertie editor and not in preview mode, obviously everything is correct and works... how clueless I am :slight_smile:
