Hi all,
I need to bind a tag to a horizontal line so it will rotate from -0.0 Deg to -90.0 Deg. I am trying to use an expression but I can’t get it to work.
My attempt is as follows:
[color=#0000FF]if[/color] ([color=#BF00FF]{Damper.damper::FieldFB}[/color]<=10, [color=#BF00FF]{angleDegrees}[/color]= 9.0,
[color=#0000FF]if[/color] ([color=#BF00FF]{Damper.damper::FieldFB}[/color]<=20, [color=#BF00FF]{angleDegrees}[/color]= 18.0,
‘Damper.damper::FieldFB’ is a UDT property which ranges from 0-100. ‘angleDegrees’ is the property script name for the line.
I would then continue this changing the values as often as I need to, to make the line rotate at regular intervals.
BUT IT WONT WORK ![]()
Any feedback is greatly appreciated.
Thank you.
