Linear Scale legend on both sides
For certain application I wanted to show linear scale with a nice visual to show CV and SP in the same scale. Since the control is so nice, there is essentially 1 Deg temp difference. I was wondering if it is possible to show CV text on the left side and SP text on the right side of the scale to easy readability ?
Figure 1.
  • Duplicate the linear scale and position it to the right of the original.
  • Delete the unwanted indicators object from the first scale.
  • Delete the (other) unwanted indicators object from the second scale.
  • On the second scale,
    • Set mirror : true.
    • Set majorTicks.color opacity to 0. Do the same for minorTicks.color and fineTicks.color.
I think that's it. The only problem I didn't resolve is the excessive gap between the green arrow and 'SP'.
Figure 2.
You could fix that by hiding the built-in labels and adding your own at the top or bottom with the advantage of a narrower gauge.
@Transistor Thank you for the work around, I wish this was a standard object in Ignition, so many industrial gadgets show SP and PV on the same gauge. Until then this will get the job done :folded_hands:
