I’m fighting with some more thin clients we got in for testing and evaluation, and found one that doesn’t have nohup. For those who don’t know what is nohup is, either did I until yesterday. It’s evidently pretty common in /usr/bin, part of coreutils, and is used for running applications that should ignore hangups so the program can run in the background without being affected by closed shell/terminal sessions.
The problem is my thin client doesn’t have it installed and it’s almost impossible to install it due to a locked down filesystem (WYSE’s Suse Linux Enterprise Thin Client OS) and all the damn dependencies, no package manager other than rpm, etc.
So, is there a way to have clientlauncher.sh run the java command WITHOUT nohup? If I remove the nohup from the launch command below, it works fine. I know this is a long-shot request for help
Starting Java with the following parameters:nohup java -classpath /read-write/ignition_clientlauncher/clientlauncher-data/launchclient.jar -Djavaws.sr.gateway.addr.0=1.1.1.1:8088/main -Djavaws.sr.scope=C -Djavaws.sr.launchts=1398267098094 -Djavaws.sr.main=com.inductiveautomation.factorypmi.application.runtime.ClientLaunchHook -Dinitial.heap.size=32M -Dmax.heap.size=256M -Djava.vm.args="-XX:MaxPermSize=128m" -Dsun.java2d.d3d=false -Djavaws.sr.project=OperatorCycleTimer -Djavaws.sr.screen=0 com.inductiveautomation.ignition.client.launch.BootstrapSwingFS &
