Linux Remote Desktop issue
I have Ignition 8.3.7 installed on a linux box. Whenever I try to do anything in Ignition Designer, a popup tells me "An app want to share your screen. Choose what you'd like to share". I can't seem to find a way to please the system such that this popup stops appearing. Any advice?
Run your designer locally. Connect directly to the gateway through your VPN instead of indirectly through remote desktop. The native connection to the gateway is far more bandwidth efficient than an RDP session, for most tasks.
I'm guessing it's not actually RDP, and he's running into this: Ignition 8.1.45 designer asking for monitor sharing - #8 by Kevin.Herron
Ah. Is that a Wayland-only issue? I run everything under X11 due to NVidia issues in Wayland, and I've never seen that.
Yeah, Wayland/XWayland, plus the synthetica look and feel doing some stupid screenshot-based fallback on Linux when rendering shadows around menus fails or something.
I am running designer on the same machine as gateway. No VPN being used. System details: System Details Report
Report details
  • Date generated: 2026-07-31 11:29:09
Hardware Information:
  • Hardware Model: Dell Inc. Inspiron 3593
  • Memory: 16.0 GiB
  • Processor: Intel® Core™ i7-1065G7 Ă— 8
  • Graphics: Intel® Iris® Plus Graphics (ICL GT2)
  • Disk Capacity: 1.0 TB
Software Information:
  • Firmware Version: 1.30.0
  • OS Name: CachyOS
  • OS Build: (null)
  • OS Type: 64-bit
  • GNOME Version: 50
  • Windowing System: Wayland
  • Kernel Version: Linux 7.1.5-1-cachyos
Did you read the thread I linked to?
I did. But how does one "start the designer withDawt.robot.screenshotMethod=x11"/
this, perhaps??
additionally, I have the same problem with KDE and Gnome
setting jvm arguments to dawt.robot.screenshotMethod=x11 produces this:
You're missing the hyphen/dash in front.
solved!!! -Dawt.robot.screenshotMethod=x11 did the trick. You, Kevin Herron, are a steely-eyed missile man. Grazie Mille
