Linux server - Log error
8.1.7
I got that error on a Linux server and don’t know what it is and where it comes from.
...com.inductiveautomation.ignition.common.	06Aug2021 08:14:01	Error parsing value. Data type: Int4, value: "2#1001"
java.lang.NumberFormatException: For input string: "2#1001"
at java.base/java.lang.NumberFormatException.forInputString(Unknown Source)
at java.base/java.lang.Integer.parseInt(Unknown Source)
at com.inductiveautomation.ignition.common.gson.JsonPrimitive.getAsInt(JsonPrimitive.java:264)
at com.inductiveautomation.ignition.common.tags.config.TagGson.deserializeValue(TagGson.java:800)
at com.inductiveautomation.ignition.common.tags.config.TagGson$PropertySetTypeAdapter.deserializeJsonObject(TagGson.java:611)
at com.inductiveautomation.ignition.common.tags.config.TagGson$PropertySetTypeAdapter.deserialize(TagGson.java:566)
at com.inductiveautomation.ignition.common.tags.config.TagGson$PropertySetTypeAdapter.deserialize(TagGson.java:515)
at com.inductiveautomation.ignition.common.gson.internal.bind.TreeTypeAdapter.read(TreeTypeAdapter.java:69)
at com.inductiveautomation.ignition.common.gson.Gson.fromJson(Gson.java:927)
at com.inductiveautomation.ignition.common.gson.Gson.fromJson(Gson.java:994)
at com.inductiveautomation.ignition.common.gson.internal.bind.TreeTypeAdapter$GsonContextImpl.deserialize(TreeTypeAdapter.java:162)
at com.inductiveautomation.ignition.common.tags.config.TagGson$PropertySetTypeAdapter.deserializeJsonObject(TagGson.java:624)
at com.inductiveautomation.ignition.common.gson.Gson.fromJson(Gson.java:967)
at com.inductiveautomation.ignition.common.tags.TagUtilities.toTagConfiguration(TagUtilities.java:128)
at com.inductiveautomation.ignition.common.script.builtin.AbstractTagUtilities.dictToTagEdits(AbstractTagUtilities.java:193)
at com.inductiveautomation.ignition.common.script.builtin.AbstractTagUtilities.lambda$configure$0(AbstractTagUtilities.java:154)
at java.base/java.util.stream.ReferencePipeline$7$1.accept(Unknown Source)
at java.base/java.util.Iterator.forEachRemaining(Unknown Source)
at java.base/java.util.Spliterators$IteratorSpliterator.forEachRemaining(Unknown Source)
at java.base/java.util.stream.AbstractPipeline.copyInto(Unknown Source)
at java.base/java.util.stream.AbstractPipeline.wrapAndCopyInto(Unknown Source)
at java.base/java.util.stream.ReduceOps$ReduceOp.evaluateSequential(Unknown Source)
at java.base/java.util.stream.AbstractPipeline.evaluate(Unknown Source)
at java.base/java.util.stream.ReferencePipeline.collect(Unknown Source)
at com.inductiveautomation.ignition.common.script.builtin.AbstractTagUtilities.configure(AbstractTagUtilities.java:154)
at jdk.internal.reflect.GeneratedMethodAccessor387.invoke(Unknown Source)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:188)
at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.__call__(ScriptManager.java:539)
at org.python.core.PyObject.__call__(PyObject.java:515)
at org.python.core.PyObject.__call__(PyObject.java:519)
at org.python.pycode._pyx4429.createUDT$29(:1005)
at org.python.pycode._pyx4429.call_function()
at org.python.core.PyTableCode.call(PyTableCode.java:171)
at org.python.core.PyBaseCode.call(PyBaseCode.java:308)
at org.python.core.PyFunction.function___call__(PyFunction.java:471)
at org.python.core.PyFunction.__call__(PyFunction.java:466)
at org.python.core.PyFunction.__call__(PyFunction.java:456)
at org.python.pycode._pyx4429.createType$26(:606)
at org.python.core.PyBaseCode.call(PyBaseCode.java:154)
at org.python.core.PyFunction.__call__(PyFunction.java:423)
at org.python.pycode._pyx4429.browseTypes$44(:1992)
at org.python.core.PyBaseCode.call(PyBaseCode.java:139)
at org.python.core.PyFunction.__call__(PyFunction.java:413)
at org.python.pycode._pyx4429.createTags$30(:1033)
at org.python.core.PyBaseCode.call(PyBaseCode.java:171)
at org.python.core.PyFunction.__call__(PyFunction.java:434)
at org.python.pycode._pyx4429.browseXML$51(:2183)
at org.python.pycode._pyx4429.fromXML$54(:2316)
at org.python.pycode._pyx4510.handleMessage$1(:14)
at org.python.pycode._pyx4510.call_function()
at org.python.core.PyFunction.__call__(PyFunction.java:461)
at com.inductiveautomation.ignition.common.script.ScriptManager.runFunction(ScriptManager.java:842)
at com.inductiveautomation.ignition.common.script.ScriptManager.runFunction(ScriptManager.java:824)
at com.inductiveautomation.ignition.gateway.project.ProjectScriptLifecycle$TrackingProjectScriptManager.runFunction(ProjectScriptLifecycle.java:681)
at com.inductiveautomation.ignition.common.script.message.MessageHandlerRunnable.run(MessageHandlerRunnable.java:114)
...com.inductiveautomation.ignition.common.	06Aug2021 08:14:01	Error parsing value. Data type: Int4, value: "2#1000"
java.lang.NumberFormatException: For input string: "2#1000"
That looks like someone trying to use a Rockwell-style binary constant somewhere.
^ “somewhere” possibly being a call to system.tag.configure in a message handler?
I have a script that run a message handler to create/update my tags, so yes I do a system.tag.configure
On Windows i don’t get any error, only on Linux
It’s the java runtime parsing that string and giving the error, so there must be a difference in the runtimes.
