List of controls within a container
Hello,
I want to write a general purpose function to enable or disable each control inside a container,
something like this:
panel=event.source.parent.getComponent('someContainer')
for ctl in panel.controls:
   print ctl.name
   ctl.enabled=1
But I dont know if there is a property that has a list of all the controls.
Is there a way to do this?
Thank you.
Yes, you can do the following:cont = event.source.parent.getComponent("someContainer") for comp in cont.getComponents(): print comp.name comp.enabled = 1
Thank you very much Travis!
This is great!
Hello Travis,
Taking this code one step ahead… is there a way to determine what type of component is in the cycle?
For instance, let’s say I only want to disable the text fields but not the numeric fields.
Something like:
    print comp.name
    if comp.type=="textField":
          comp.enabled = 0
Thank you
Yes, but the type is kind of hidden to you:cont = event.source.parent.getComponent("someContainer") for comp in cont.getComponents(): print comp.name if str(comp.getClass()).endswith("PMINumericTextField"): comp.enabled = 0Now to get the actual type you can copy the component from the designer and paste it into a text editor. There you will see the type like PMINumericTextField.
