I found this topic elsewhere in Ignition problems but the topic was locked.
Since I’m looking for the same result, I’ll repost this issue.
[code]dataTable = event.source.parent.getComponent(‘Table’).data
pyDataIn = system.dataset.toPyDataSet(dataTable)
headers = [“Shift Name”]
data = []
for row in pyDataIn:
shiftName = row[“Shiftname”]
selected = row[“Select”]
if selected:
data.append([shiftName])
This error only appears in preview mode in the designer.
if len(data):
newDs = system.dataset.toDataSet(headers, data)
event.source.parent.getComponent(‘Table’).Select = newDs[/code]
This is supposed to take a dataset from a table component and loop through the rows checking to see which rows have the selected value True and then create another dataset of the number of “selected” rows.
The code seems to work, BUT I am getting an error anyways about this
File “event:propertyChange”, line 4, in
TypeError: toPyDataSet(): 1st arg can’t be coerced to com.inductiveautomation.ignition.common.Dataset
Ignition v7.6.6 (b2014040112)
Java: Sun Microsystems Inc. 1.6.0_45
