I am running an Ignition gateway connected to an opc server with opc tags. I have different opc tags configured for different possible tags the opc server may publish based on its configuration.
When I switch the opc server to publish one config of tags instead of the other, Ignition fails to populate the new opc tags. I get the following error:
Restarting the gateway immediately resolves the error.
Any ideas what's going on here?
