tmahaf
November 8, 2022, 12:40pm
1
Hello,
I have a IP camera that setup to stream RTSP via R.264 encoding. I am able to stream RTSP directly from the camera using VLC with this endpoint:
rtsp://my-username:my-password@192.168.0.186:554/cam/realmonitor?channel=1&subtype=1
My ignition webserver is on the same network (same computer that I am able to stream using VLC), but I am unable to get the Perspective video player to work. The online documentation for the Perspective Video Player doesn't describe what is needed for the connection string.
Thank you!
Perspective video payer dont support rtsp protocol
You can try those workaround:
VIDEO starter kit for Ignition Vision and Perspective 8.1 !
3 use case:
A standalone video wall Ignition Vision project
A video wall Ignition Vision Project with the choices of the cameras driven by an Ignition Perspective Project
A video stream displayed in a standalone Ignition Perspective Project
(3. is a tricky and complex solution. Don't use it in production without running test over time)
[demo_vision]
[demo_perspective]
Ignition Vision edition support :
RTS…
