Loader gif in top of table?
Hello!
Can I put an image in top of a table?
I just figured out how to add a loader to my table while loading data. On the button that triggers the load I added:
# Set the loading state to True (show loader)
	self.getSibling("TabContainer").custom.isLoading = True
and at the end of the code when table is loaded:
finally:
	    # Set the loading state to False (hide loader) after the query is completed
	    self.getSibling("TabContainer").custom.isLoading = False
then my custom.isLoading property is binded to the meta.visible of the container in wich I added the loader.
Just use a popup.
Here's a simplified version of what I use:
decorator
from functools import wraps
def loading(message="MESSAGE"):
	def _loading(func):
		@wraps(func)
		def wrapper(*args, **kwargs):
			system.perspective.openPopup(
				id = 'loader',
				view = "components/loader/popup",
				position = {'width': "300px", 'height': "300px"},
				showCloseIcon = False,
				draggable = False,
				modal = True,
				resizable = False,
				overlayDismiss = False,
				params = {
					'message': message
			popup_open = True
			try:
				ret = func(*args, **kwargs)
			except:
				raise
			finally:
				system.perspective.closePopup('loader')
				return ret
		return wrapper
	return _loading
popup view json
  "custom": {},
  "params": {
    "message": "loading..."
  "propConfig": {
    "params.message": {
      "paramDirection": "input",
      "persistent": true
  "props": {
    "defaultSize": {
      "height": 300,
      "width": 300
  "root": {
    "children": [
        "meta": {
          "name": "spinning-circles"
        "position": {
          "basis": "80px"
        "props": {
          "elements": [
              "elements": [
                  "elements": [
                      "cx": "42.601",
                      "cy": "11.462",
                      "elements": [
                          "attributeName": "fill-opacity",
                          "calcMode": "linear",
                          "dur": "1.3s",
                          "name": "animate",
                          "repeatCount": "indefinite",
                          "type": "animate",
                          "values": "1;0;0;0;0;0;0;0"
                      "fill": {
                        "opacity": "1",
                        "paint": "#fff"
                      "name": "circle",
                      "r": "5",
                      "type": "circle"
                      "cx": "49.063",
                      "cy": "27.063",
                      "elements": [
                          "dur": "1.3s",
                          "name": "animate",
                          "type": "animate",
                          "values": "0;1;0;0;0;0;0;0"
                      "fill": {
                        "opacity": "0",
                        "paint": "#fff"
                      "name": "circle",
                      "r": "5",
                      "type": "circle"
                      "cx": "42.601",
                      "cy": "42.663",
                      "elements": [
                          "dur": "1.3s",
                          "name": "animate",
                          "type": "animate",
                          "values": "0;0;1;0;0;0;0;0"
                      "fill": {
                        "opacity": "0",
                        "paint": "#fff"
                      "name": "circle",
                      "r": "5",
                      "type": "circle"
                      "cx": "27",
                      "cy": "49.125",
                      "elements": [
                          "dur": "1.3s",
                          "name": "animate",
                          "type": "animate",
                          "values": "0;0;0;1;0;0;0;0"
                      "fill": {
                        "opacity": "0",
                        "paint": "#fff"
                      "name": "circle",
                      "r": "5",
                      "type": "circle"
                      "cx": "11.399",
                      "cy": "42.663",
                      "elements": [
                          "dur": "1.3s",
                          "name": "animate",
                          "type": "animate",
                          "values": "0;0;0;0;1;0;0;0"
                      "fill": {
                        "opacity": "0",
                        "paint": "#fff"
                      "name": "circle",
                      "r": "5",
                      "type": "circle"
                      "cx": "4.938",
                      "cy": "27.063",
                      "elements": [
                          "dur": "1.3s",
                          "name": "animate",
                          "type": "animate",
                          "values": "0;0;0;0;0;1;0;0"
                      "fill": {
                        "opacity": "0",
                        "paint": "#fff"
                      "name": "circle",
                      "r": "5",
                      "type": "circle"
                      "cx": "11.399",
                      "cy": "11.462",
                      "elements": [
                          "dur": "1.3s",
                          "name": "animate",
                          "type": "animate",
                          "values": "0;0;0;0;0;0;1;0"
                      "fill": {
                        "opacity": "0",
                        "paint": "#fff"
                      "name": "circle",
                      "r": "5",
                      "type": "circle"
                      "cx": "27",
                      "cy": "5",
                      "elements": [
                          "dur": "1.3s",
                          "name": "animate",
                          "type": "animate",
                          "values": "0;0;0;0;0;0;0;1"
                      "fill": {
                        "opacity": "0",
                        "paint": "#fff"
                      "name": "circle",
                      "r": "5",
                      "type": "circle"
                  "name": "group",
                  "stroke": {
                    "paint": "#FFF",
                    "width": "1.5"
                  "transform": "translate(2 1)",
                  "type": "group"
              "fill": {
                "paint": "transparent",
                "rule": "evenodd"
              "name": "group",
              "type": "group"
          "viewBox": "0 0 58 58"
        "type": "ia.shapes.svg"
        "meta": {
          "name": "Label"
        "propConfig": {
          "props.text": {
            "binding": {
              "config": {
                "path": "view.params.message"
              "type": "property"
        "props": {
          "textStyle": {
            "color": "white"
        "type": "ia.display.label"
    "meta": {
      "name": "root"
    "props": {
      "alignItems": "center",
      "direction": "column",
      "justify": "center",
      "style": {
        "gap": "20px"
    "type": "ia.container.flex"
css
#popup-loader {
	border: none;
	outline: none;
	background: transparent;
	box-shadow: none;
	text-shadow: 2px 2px 3px black;
	font-size: 1.3em;
Here's how to use it:
When you have a function that may take time to run, put it in your library, and decorate it with the loading decorator.
It should look like this:
@some_module.loading("message")
def slow_function():
    sleep(20)
Now call that function in your transforms or whatever. That's it.
You can replace the loading animation by just replacing the svg in the popup. You can find some here: GitHub - SamHerbert/SVG-Loaders: Loading icons and small animations built with pure SVG.
I also have a version of that popup that uses css for the animation if you prefer.
Thanks Pascal for your answer!, I will try this method.
I only just found this, or maybe I saw it back when you posted when I didn’t understand decorators and didn’t appreciate its genius, but this is really cool! Extremely easy to use.
One nice alternative would be the ability to tie it to a single component only so that the whole screen isn’t affected. But both have their use cases
Note that because it calls a perspective function, decorated functions will raise an error when called from the script console.
The "real" version I use handles this by checking for specific errors:
from java.lang import IllegalArgumentException, IllegalStateException
	def _loading(func):
		@wraps(func)
			try:
					id = 'loader',
					draggable = False,
					modal = True,
					resizable = False,
					params = {
						'message': message
				popup_open = True
			except AttributeError:
				# vision/console scope error
				popup_open = False
			except IllegalArgumentException:
				# gateway scope error - Perspective session doesn't exist
				popup_open = False
			except IllegalStateException:
				# gateway scope error - Perspective session was disconnected
				popup_open = False
			try:
				return func(*args, **kwargs)
			except:
				raise
			finally:
				if popup_open:
					try:
					except:
						pass
		return wrapper
	return _loading
This may not be complete, or even entirely correct, as it was written through trial an error...
I handle this by adding a scope check.
if utils.env.isPerspective(): # custom script
    system.perspective.openPopup(...)
You know what they say: Ask for forgiveness, not for permission.
I don't always agree, but, hey, at least there's some literature to make me feel better about myself when I just try to throw stuff at the interpreter and see what sticks.
