Loader in table while changing parameters
Hello!
I have a table with a named query that has a date parameter, when I change the parameter the data load on the table but take a while as it´s large.
There is a quick way to show a loader while the new data is loading?
What I´m using now is a emptyMessage.noData.text
wich shows the message while there is no data at all but not when there is data.
Add an onChange event to the date selection to wipe the table's data before it triggers the reload.
Hello!
I´m trying adding to my change script something like:
def valueChanged(self, previousValue, currentValue, origin, missedEvents):
    if event.propertyName == "props.value":
        table = self.getSibling("Table_0")
        headers = []  # No columns
        data = []  # No data rows
        emptyDataset = system.dataset.toDataSet(headers, data)
        table.props.data = emptyDataset
        if hasattr(self.getParent(), 'updateTableData'):
            self.getParent().updateTableData()
but not working...
Can you show the query ? That seems way too long for just a query, even for a large amount of data.
You don't need to filter on property name in perspective, the script will only trigger for this property.
And as usual, "not working" is not a sufficient error message. We need details.
But... if you just want to wipe the table clean, why is the script so complicated ?
Something like self.getSibling('table').props.data = None should work
Tip: should your column header be kWh Used (not "kW Used"). Don't confuse power and energy. Same for your other columns, I suspect.
That is something you do in Vision, not Perspective. In the latter, change events are attached to just the one property.
What everyone else has said, plus, I'm not sure why you are referencing a sibling, simply:
self.props.data = None
...should work.
This is the table with the date parameter wich filter with the date input
The data is very latge, the query
WITH MAXKW AS (
    SELECT
        TS.CODIGO, TS.ORDEN_DNF,
        MAX(TM.KWGEN) AS MAX_TOTAL_HIST
    FROM T_MEDIDAS_TE TM
    JOIN T_Sede TS ON TM.id_sede = TS.id_sede
    WHERE TM.timestamp BETWEEN ADD_MONTHS(TRUNC(TO_DATE(:startdate, 'YYYY-MM-DD HH24:MI:SS')), -12) AND TRUNC(TO_DATE(:startdate, 'YYYY-MM-DD HH24:MI:SS')) + INTERVAL '1' YEAR - INTERVAL '1' SECOND
      AND TS.ORDEN_DNF IS NOT NULL
    GROUP BY TS.Codigo, TS.ORDEN_DNF
HISTMAXKW AS (
    SELECT
        MAX(TM.KWGEN) AS HISTMAX
    WHERE TS.ORDEN_DNF IS NOT NULL
AVGKW AS (
    SELECT
        TS.COD_DNF,
        TS.KWCON AS KWCON,
        TS.KWLIM AS KWLIM,
        AVG(TM.KWGEN) AS AVG_KW_GEN,
        MAX(TM.KWGEN) AS MAX_KW_PERIOD,
        AVG(TM.KWCLT) AS AVG_KW_CLT,
        MAX(TM.KWCLT) AS MAX_KW_CLT,
        AVG(TM.KWIT) AS AVG_KW_IT,
        MAX(TM.KWIT) AS MAX_KW_IT,
        TS.DNF_BAT AS DNF,
        TS.DNF_BAT_10 AS DNF10,
        TS.PRVDNF AS PRVDNF,
        MAX(TM.PENEJE) KEEP (DENSE_RANK FIRST ORDER BY TM.TIMESTAMP DESC) AS "PENEJE",
        0 AS RAMPA
    WHERE TM.timestamp >= TO_DATE(:startdate, 'YYYY-MM-DD HH24:MI:SS')
      AND TM.timestamp < TO_DATE(:startdate, 'YYYY-MM-DD HH24:MI:SS') + INTERVAL '1' YEAR
    GROUP BY
        TO_CHAR(TM.timestamp, 'YYYY'),
        TO_CHAR(TM.timestamp, 'IW'),
        TS.Codigo,
        TS.ORDEN_DNF,
        TS.KWCON,
        TS.KWLIM,
        TS.COD_DNF,
        TS.DNF_BAT,
        TS.DNF_BAT_10,
        TS.PRVDNF
SELECT
    STM.CODIGO AS "CODE",
    STM.COD_DNF AS "DNF code",
    STM.KWCON AS "kW Cont.",
    STM.KWLIM AS "kW Lim.",
    STM.AVG_KW_GEN AS "kW Used",
Because the change script is not on the table itself, but on the date selector.
    ADD_MONTHS(
    ) AND
        + INTERVAL '1' YEAR - INTERVAL '1' SECOND ...
Are you saving datetime as strings? (Bad)
Should I fix that?
Dates and timestamps should always be stored as DateTime type. They can be indexed easily and filtered quickly. You also have the ability to store in UTC so that you don't have (as much) trouble with daylight savings, etc.
Ok, will try the conversion, thanks Transistor
I was doing a work around for the date string
    import system
system.date.format
    formatted_date = system.date.format(value, 'yyyy-MM-dd HH:mm:ss')
    return formatted_date
will try do it straight
Don't import system. It's already available without importing it.
And Transistor is 200% right: use the appropriate data type.
