Hi, My ignition web portal suddenly stopped opening from google chrome and can you check what is the wrong ? Below i have entered the Wrap file log for further info.
STATUS | wrapperm | 2022/05/09 11:07:26 | Ignition service installed.
STATUS | wrapperm | 2022/05/09 11:07:26 | Starting the Ignition service…
STATUS | wrapper | 2022/05/09 11:07:26 | → Wrapper Started as Service
STATUS | wrapper | 2022/05/09 11:07:27 | Java Service Wrapper Standard Edition 64-bit 3.5.42
STATUS | wrapper | 2022/05/09 11:07:27 | Copyright (C) 1999-2020 Tanuki Software, Ltd. All Rights Reserved.
STATUS | wrapper | 2022/05/09 11:07:27 | http://wrapper.tanukisoftware.com
STATUS | wrapper | 2022/05/09 11:07:27 | Licensed to Inductive Automation for Inductive Automation
STATUS | wrapper | 2022/05/09 11:07:28 | Launching a JVM…
INFO | jvm 1 | 2022/05/09 11:07:28 | WrapperManager: Initializing…
INFO | jvm 1 | 2022/05/09 11:07:29 | 11:07:29,119 |-INFO in ch.qos.logback.classic.LoggerContext[default] - Found resource [data\logback.xml] at [file:/C:/Program%20Files/Inductive%20Automation/Ignition/data/logback.xml]
INFO | jvm 1 | 2022/05/09 11:07:29 | 11:07:29,171 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - About to instantiate appender of type [ch.qos.logback.core.ConsoleAppender]
INFO | jvm 1 | 2022/05/09 11:07:29 | 11:07:29,173 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - Naming appender as [SysoutAppender]
INFO | jvm 1 | 2022/05/09 11:07:29 | 11:07:29,177 |-INFO in ch.qos.logback.core.joran.action.NestedComplexPropertyIA - Assuming default type [ch.qos.logback.classic.encoder.PatternLayoutEncoder] for [encoder] property
INFO | jvm 1 | 2022/05/09 11:07:29 | 11:07:29,190 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - About to instantiate appender of type [com.inductiveautomation.logging.SQLiteAppender]
INFO | jvm 1 | 2022/05/09 11:07:29 | 11:07:29,194 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - Naming appender as [DB]
INFO | jvm 1 | 2022/05/09 11:07:29 | 11:07:29,388 |-INFO in ch.qos.logback.core.db.DataSourceConnectionSource@539428d4 - Driver name=SQLite JDBC
INFO | jvm 1 | 2022/05/09 11:07:29 | 11:07:29,388 |-INFO in ch.qos.logback.core.db.DataSourceConnectionSource@539428d4 - Driver version=3.23.1
INFO | jvm 1 | 2022/05/09 11:07:29 | 11:07:29,388 |-INFO in ch.qos.logback.core.db.DataSourceConnectionSource@539428d4 - supportsGetGeneratedKeys=true
INFO | jvm 1 | 2022/05/09 11:07:29 | 11:07:29,408 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - About to instantiate appender of type [ch.qos.logback.classic.AsyncAppender]
INFO | jvm 1 | 2022/05/09 11:07:29 | 11:07:29,410 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - Naming appender as [SysoutAsync]
INFO | jvm 1 | 2022/05/09 11:07:29 | 11:07:29,411 |-INFO in ch.qos.logback.core.joran.action.AppenderRefAction - Attaching appender named [SysoutAppender] to ch.qos.logback.classic.AsyncAppender[SysoutAsync]
INFO | jvm 1 | 2022/05/09 11:07:29 | 11:07:29,411 |-INFO in ch.qos.logback.classic.AsyncAppender[SysoutAsync] - Attaching appender named [SysoutAppender] to AsyncAppender.
INFO | jvm 1 | 2022/05/09 11:07:29 | 11:07:29,411 |-INFO in ch.qos.logback.classic.AsyncAppender[SysoutAsync] - Setting discardingThreshold to 51
INFO | jvm 1 | 2022/05/09 11:07:29 | 11:07:29,412 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - About to instantiate appender of type [ch.qos.logback.classic.AsyncAppender]
INFO | jvm 1 | 2022/05/09 11:07:29 | 11:07:29,413 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - Naming appender as [DBAsync]
INFO | jvm 1 | 2022/05/09 11:07:29 | 11:07:29,413 |-INFO in ch.qos.logback.core.joran.action.AppenderRefAction - Attaching appender named [DB] to ch.qos.logback.classic.AsyncAppender[DBAsync]
INFO | jvm 1 | 2022/05/09 11:07:29 | 11:07:29,413 |-INFO in ch.qos.logback.classic.AsyncAppender[DBAsync] - Attaching appender named [DB] to AsyncAppender.
INFO | jvm 1 | 2022/05/09 11:07:29 | 11:07:29,413 |-INFO in ch.qos.logback.classic.AsyncAppender[DBAsync] - Setting discardingThreshold to 51
INFO | jvm 1 | 2022/05/09 11:07:29 | 11:07:29,413 |-INFO in ch.qos.logback.classic.joran.action.RootLoggerAction - Setting level of ROOT logger to INFO
INFO | jvm 1 | 2022/05/09 11:07:29 | 11:07:29,413 |-INFO in ch.qos.logback.core.joran.action.AppenderRefAction - Attaching appender named [SysoutAsync] to Logger[ROOT]
INFO | jvm 1 | 2022/05/09 11:07:29 | 11:07:29,413 |-INFO in ch.qos.logback.core.joran.action.AppenderRefAction - Attaching appender named [DBAsync] to Logger[ROOT]
INFO | jvm 1 | 2022/05/09 11:07:29 | 11:07:29,413 |-INFO in ch.qos.logback.classic.joran.action.ConfigurationAction - End of configuration.
INFO | jvm 1 | 2022/05/09 11:07:29 | 11:07:29,414 |-INFO in ch.qos.logback.classic.joran.JoranConfigurator@6c3d7baa - Registering current configuration as safe fallback point
INFO | jvm 1 | 2022/05/09 11:07:29 | 11:07:29,440 |-INFO in ch.qos.logback.classic.jul.LevelChangePropagator@12b90e5d - Propagating INFO level on Logger[ROOT] onto the JUL framework
INFO | jvm 1 | 2022/05/09 11:07:29 | W [WebResourceManagerImpl ] [05:37:29]: Unable to read “gateway.metroKeystoreAlias” gateway.xml property. Assuming metro keystore alias is: metro-key
INFO | jvm 1 | 2022/05/09 11:07:29 | I [o.e.j.u.log ] [05:37:29]: Logging initialized @974ms to org.eclipse.jetty.util.log.Slf4jLog
INFO | jvm 1 | 2022/05/09 11:07:29 | I [g.WebServerManager ] [05:37:29]: Starting setup
INFO | jvm 1 | 2022/05/09 11:07:29 | I [g.WebServerManager ] [05:37:29]: gateway.forceSecureRedirect property is not set. Defaulting to false
INFO | jvm 1 | 2022/05/09 11:07:29 | I [g.WebServerManager ] [05:37:29]: gateway.includedCipherSuites property is not set. Defaulting to
INFO | jvm 1 | 2022/05/09 11:07:29 | I [g.WebServerManager ] [05:37:29]: gateway.excludedCipherSuites property is not set. Defaulting to
INFO | jvm 1 | 2022/05/09 11:07:29 | I [g.WebServerManager ] [05:37:29]: gateway.publicAddress.autoDetect property is not set. Defaulting to true
INFO | jvm 1 | 2022/05/09 11:07:29 | I [g.WebServerManager ] [05:37:29]: gateway.publicAddress.address property is not set. Defaulting to
INFO | jvm 1 | 2022/05/09 11:07:29 | I [g.WebServerManager ] [05:37:29]: gateway.publicAddress.httpPort property is not set. Defaulting to
INFO | jvm 1 | 2022/05/09 11:07:29 | I [g.WebServerManager ] [05:37:29]: gateway.publicAddress.httpsPort property is not set. Defaulting to
INFO | jvm 1 | 2022/05/09 11:07:29 | I [g.WebServerManager ] [05:37:29]: gateway.useProxyForwardedHeader property is not set. Defaulting to false
INFO | jvm 1 | 2022/05/09 11:07:29 | I [g.WebServerManager ] [05:37:29]: gateway.resolveHostNames property is not set. Defaulting to false
INFO | jvm 1 | 2022/05/09 11:07:29 | I [g.WebServerManager ] [05:37:29]: Setup complete
INFO | jvm 1 | 2022/05/09 11:07:29 | I [Commissioning ] [05:37:29]: Resources needing commissioning: eula,authSetup,connections,activated
INFO | jvm 1 | 2022/05/09 11:07:29 | I [Commissioning ] [05:37:29]: Commissioning State updated from commissioning to needs_commissioning
INFO | jvm 1 | 2022/05/09 11:07:29 | I [g.WebServerManager ] [05:37:29]: Starting up
INFO | jvm 1 | 2022/05/09 11:07:29 | I [C.SecureRandomProvider ] [05:37:29]: Secure random seed generated in 0ms
INFO | jvm 1 | 2022/05/09 11:07:29 | I [o.e.j.s.Server ] [05:37:29]: jetty-9.4.45.v20220203; built: 2022-02-03T09:14:34.105Z; git: 4a0c91c0be53805e3fcffdcdcc9587d5301863db; jvm 11.0.14.1+1-LTS
INFO | jvm 1 | 2022/05/09 11:07:30 | I [o.e.j.s.session ] [05:37:29]: DefaultSessionIdManager workerName=node0
INFO | jvm 1 | 2022/05/09 11:07:30 | I [o.e.j.s.session ] [05:37:29]: No SessionScavenger set, using defaults
INFO | jvm 1 | 2022/05/09 11:07:30 | I [o.e.j.s.session ] [05:37:29]: node0 Scavenging every 660000ms
INFO | jvm 1 | 2022/05/09 11:07:30 | I [o.e.j.s.h.ContextHandler ] [05:37:29]: Started o.e.j.w.WebAppContext@287c46c0{Commissioning,/,file:///C:/Program%20Files/Inductive%20Automation/Ignition/webserver/webapps/commissioning/,AVAILABLE}
INFO | jvm 1 | 2022/05/09 11:07:30 | I [o.e.j.s.AbstractConnector ] [05:37:29]: Started ServerConnector@44634257{HTTP/1.1, (http/1.1)}{0.0.0.0:8088}
INFO | jvm 1 | 2022/05/09 11:07:30 | I [o.e.j.s.Server ] [05:37:29]: Started @1336ms
INFO | wrapperm | 2022/05/09 11:07:31 | Waiting to start…
STATUS | wrapperm | 2022/05/09 11:07:32 | Ignition service started.
