Local time different from system time
Hello,
I'm pretty new working with ignition software and I have a trouble trying to change the local hour in my application.
I have an hour offset (+1) between the time in my ignition gateway and my windows time.
I already look into ignition.conf but nothing about an timezone.
Then I tried to override the timezone from project properties menu but no changes.
Any idea to keep trying?
There is a project setting to control what timezone the clients use. Yours is probably set to "Gateway Timezone".
I tried to change this option but looking into tag system/Timezone the value is not the option that I set in the project properties window.
This would be the Gateway Timezone.
The tag system runs outside of projects.
That tag is global, not project specific. Use the timezone from your session props if you need to compute manually.
