Hello! a pleasure to greet you. I am having the following problem, as a context i am running ignition in an Azure virtual machine, the problem is that the local time of my gateway is not the same of my virtual machine. how do i make the gateway to have the time of my machine?
It could be that the system timezone differs from that of your user. You can explicitly set the timezone for Ignition through the data/ignition.conf file: Gateway Configuration File Reference - Ignition User Manual 8.1 - Ignition Documentation
Reference the list of "TZ database names" from here: List of tz database time zones - Wikipedia
