Localhost not working
Hi there,
Im trying to access my localhost after a long time being inactive (dont think thats makes a difference) . But it seems not to want to work :frowning: .
the Localhost is unavailable.
Kind regards
Farhad Hossain
Is the gateway actually running in your system?
Assuming windows check your services
If you did the default the name should be ignition if you changed it, look for the description Ignition Gateway.
So it seems its not running. any idea on how to? :upside_down_face:
Unless I've not had enough coffee... I don't see the service installed on this PC. Are you sure you are on the correct machine?
:joy:
Ive been using the same machine for 3 years
you installed the designer launcher from somewhere...
Did your IT group uninstall the Ignition service? Or Ignition itself, possibly?
Thank you everyone for your help, ignition had to be installed again. :upside_down_face:
