Localization and Translatation Manager Scope in Components
Sure thing.
[edit]
Look for it in 7.7.4-rc1
Hi Kathy, could you please add the traslation for the power table filters, thanks
Thanks, I’ve made a ticket for that, too.
in AlarmStatusTable I have problem with translation Active Duration column. I translated formated strings in translation manager, but column values remain still in English.
I’m using version 7.7.4. Thanks
Thanks, I was able to replicate this. I’ve made a ticket for this.
Kathy,
is it now possible to translate the “Access Violation” warning window?
It should be, but it’s a key you’d never guess. :frowning:
<HTML><P><font color='red'>ACCESS VIOLATION.</font><P>You do not have the privileges to open window '%s'
I’ll make a note to talk with training about getting some way to document these better.
Hello Team,
I am stuck at one point where I need to do localization for tree view control.
But I have not found tree view item in translatable terms panel. PFB
Please help me here to add multiple language’s for all nodes of tree view?
Thanks in advance,
Umesh
The items in the tree view come from the dataset that you provide, so you need to do the translation on the dataset, either through the expression function or the scripting function.
Basically, the translatable terms on a component will focus on things we provide, not data you provide. We figure we’ve given you the tools to translate your data if you care to. :slight_smile:
Hello
I really can’t get my tree to be translated, could you set an example on how to do it?
Thx
