When I use the built-in numeric keypad it is popping up way at the bottom of the screen- actually a little off my Ignition screen and going underneath the Windows taskbar. Is there any way to control where the keypad is located?
Could it be that you’re not running 7.2.7? From the 7.2.7 release notes:
Nope, it’s 7.2.7 alright- build 170.
Ok, I see what the problem is. The fix I mentioned was only applied to the alpha numeric keyboard popup, but the same issue also affected the numeric keypad. This has been fixed for 7.2.8.
