Hello everyone,
I have a problem using some scripts in the shared library. Firstly, I created a script file in my project but then I decided to move it to the shared library, to do it, I dragged the script to the scripting global zone. Since that point I cannot open the script file and if I try to remove or rename it, a message appears:
“Unable to retrieve lock for resource ‘ScriptsName’. The resource has been changed. please update your project.”
For giving more information, the next lines appear in the output console when I do double click on the script to open it:
Exception in thread "AWT-EventQueue-2" java.lang.NullPointerException
at com.inductiveautomation.ignition.designer.scripteditor.workspace.ScriptWorkspace.askOpenReadOnly(ScriptWorkspace.java:184)
at com.inductiveautomation.ignition.designer.scripteditor.workspace.ScriptWorkspace.openScript(ScriptWorkspace.java:167)
at com.inductiveautomation.ignition.designer.scripteditor.workspace.ModuleNode.onDoubleClick(ModuleNode.java:97)
at com.inductiveautomation.ignition.designer.navtree.NavTreePanel$MouseListener$1.run(NavTreePanel.java:649)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.awt.EventQueue.access$500(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(Unknown Source)
In contrast, I can copy and paste the script and my code is there.
If any one can help me I will be thankful. Thanks.
Regards, Enrique.
P.D. I am using 7.8.2 version
I was able to replicate this in 7.8.4. I’ll open a ticket to get it fixed.
