Log entries
From the System Console, I can view up to the last 200 log entries. Is there any way to increase that number or download the logs in a text format? The exported logs are in some sort of gzipped binary format. I can pick through the contents and find some keywords, but that’s not so useful.
Is that binary format proprietary or is it just one I’m unfamiliar with?
Thats if you export the logs from the gateway. You can look at the logs if you go to the installation directory of Ignition, then go to logs then open the wrapper.log file. It is a .txt and you can view it in notepad.
