Log Error: SQLiteAppenderReader
Hello, I get an error in my Ignition gateway more than 10 times every hour. The the logger name is "SQLiteAppenderReader" and the message is "Error executing query against logs database".
What is the cause of this?
I suspect it is the internal database since I have not added any SQLite databases myself.
Here is the Call stack:
java.sql.SQLException: Unable to build a valid query with the parameters provided.
at com.inductiveautomation.ignition.gateway.logging.SQLiteAppenderReader.buildPrepStatement(SQLiteAppenderReader.java:129)
at com.inductiveautomation.ignition.gateway.logging.SQLiteAppenderReader.query(SQLiteAppenderReader.java:154)
at com.inductiveautomation.ignition.gateway.logging.GatewayLoggingManagerImpl.queryLogEvents(GatewayLoggingManagerImpl.java:144)
at com.inductiveautomation.ignition.gateway.web.pages.status.routes.LoggingRoutes.getLogs(LoggingRoutes.java:561)
at com.inductiveautomation.ignition.gateway.dataroutes.Route.service(Route.java:254)
at com.inductiveautomation.ignition.gateway.dataroutes.RouteGroupImpl.service(RouteGroupImpl.java:61)
at com.inductiveautomation.ignition.gateway.dataroutes.RouteGroupCollectionServlet.serviceInternal(RouteGroupCollectionServlet.java:59)
at com.inductiveautomation.ignition.gateway.dataroutes.AbstractRouteGroupServlet.service(AbstractRouteGroupServlet.java:38)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:590)
at org.eclipse.jetty.servlet.ServletHolder$NotAsync.service(ServletHolder.java:1410)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:764)
at org.eclipse.jetty.servlet.ServletHandler$ChainEnd.doFilter(ServletHandler.java:1665)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:527)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:131)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:578)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:122)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:223)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1570)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:221)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1383)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:176)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:484)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1543)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:174)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1305)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:129)
at com.inductiveautomation.catapult.handlers.RemoteHostNameLookupHandler.handle(RemoteHostNameLookupHandler.java:121)
at org.eclipse.jetty.rewrite.handler.RewriteHandler.handle(RewriteHandler.java:301)
at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:51)
at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:141)
at org.eclipse.jetty.server.Server.handle(Server.java:563)
at org.eclipse.jetty.server.HttpChannel.lambda$handle$0(HttpChannel.java:505)
at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:762)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:497)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:282)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:314)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:100)
at org.eclipse.jetty.io.SelectableChannelEndPoint$1.run(SelectableChannelEndPoint.java:53)
at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.runTask(AdaptiveExecutionStrategy.java:416)
at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.consumeTask(AdaptiveExecutionStrategy.java:385)
at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.tryProduce(AdaptiveExecutionStrategy.java:272)
at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.lambda$new$0(AdaptiveExecutionStrategy.java:140)
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:411)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:934)
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1078)
Caused by: org.sqlite.SQLiteException: [SQLITE_BUSY] The database file is locked (database is locked)
at org.sqlite.core.DB.newSQLException(DB.java:1141)
at org.sqlite.core.DB.newSQLException(DB.java:1152)
at org.sqlite.core.DB.throwex(DB.java:1112)
at org.sqlite.core.NativeDB.prepare_utf8(Native Method)
at org.sqlite.core.NativeDB.prepare(NativeDB.java:117)
at org.sqlite.core.DB.prepare(DB.java:267)
at org.sqlite.core.CorePreparedStatement.(CorePreparedStatement.java:44)
at org.sqlite.jdbc3.JDBC3PreparedStatement.(JDBC3PreparedStatement.java:30)
at org.sqlite.jdbc4.JDBC4PreparedStatement.(JDBC4PreparedStatement.java:25)
at org.sqlite.jdbc4.JDBC4Connection.prepareStatement(JDBC4Connection.java:34)
at org.sqlite.jdbc3.JDBC3Connection.prepareStatement(JDBC3Connection.java:155)
at org.sqlite.jdbc3.JDBC3Connection.prepareStatement(JDBC3Connection.java:135)
at com.inductiveautomation.ignition.gateway.logging.SQLiteAppenderReader.buildPrepStatement(SQLiteAppenderReader.java:110)
.. 48 common frames omitted
Does a Gateway restart resolve this?
No, I restarted the Ignition process 10 min ago, and these messages started coming as soon as it was ready.
Ok. Maybe try stopping the service, deleting the logs/system_logs.idb file (or moving/saving it somewhere), and starting it again.
If that doesn't work give support a call.
OK, I will try that. Thank you for the quick response!
Thanks, it worked.
The problem has now started appearing again, and looks the same as before. I dont think I have got the error the last two days, but today, I suddenly got two in a row (50 seconds apart).
What kind of data is stored in the file? The same logs as in Status->Diagnostics->Logs?
I see the loglist flashing right before the error appears in the log.
