Can someone explain these errors
and what I might do to correct the problem?Do you have any of the Cirrus Link MQTT modules installed, or some other 3rd party module?
They are Cirrus Link.
Well, if you’re not on the latest versions, try that. Otherwise maybe @wes0johnson knows what those mean or you can contact CL support.
These messages indicate an MQTT client is sending a malformed MQTT message. Are you using any third party MQTT clients (i.e. non-Cirrus Link clients)? I would suggest opening a support ticket by emailing this error log to support@cirrus-link.com along with any context about your setup.
