Logback cannot load SQLServerDriver
I’m trying to add an appender to to logback.xml so we can write logs to a database, as well as to the wrapper.log. I have added the DBAppender with SQLServerDriver as the driverClass, but logback is unable to load the JDBC driver class.
Here’s what I have added to logback.xml, inside the existing configuration element:
<configuration debug="true">
  <appender name="PHX" class="ch.qos.logback.classic.db.DBAppender">
    <connectionSource class="ch.qos.logback.core.db.DriverManagerConnectionSource">
      <driverClass>com.microsoft.sqlserver.jdbc.SQLServerDriver</driverClass>
      <url>jdbc:sqlserver://serverName;databaseName=database</url>
      <user>LogTest</user>
      <password>logtestpassword</password>
    </connectionSource>
  </appender>
  <root level="INFO">
    <appender-ref ref="PHX"/>
    <appender-ref ref="SysoutAsync"/>
    <appender-ref ref="DBAsync"/>
  </root>
</configuration>
The driverClass is the same as the Microsoft SQLServer driver’s Classname, and the url is configured the same way we set our database connections. I have also tried setting the url to “serverName/database”, and to use a separate element for the databaseName. Neither one seems to make a difference, and it seems the error is occurring before that, when it is unable to find the SQLServerDriver class.
Here’s what’s in the wrapper.log:
INFO   | jvm 1    | 2019/10/01 14:41:02 | WrapperManager: Initializing...
INFO   | jvm 1    | 2019/10/01 14:41:03 | 14:41:03,072 |-INFO in ch.qos.logback.classic.LoggerContext[default] - Found resource [data\\logback.xml] at [file:/C:/Program%20Files/Inductive%20Automation/Ignition/data/logback.xml]
INFO   | jvm 1    | 2019/10/01 14:41:03 | 14:41:03,148 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - About to instantiate appender of type [ch.qos.logback.classic.db.DBAppender]
INFO   | jvm 1    | 2019/10/01 14:41:03 | 14:41:03,154 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - Naming appender as [PHX]
INFO   | jvm 1    | 2019/10/01 14:41:03 | 14:41:03,160 |-ERROR in ch.qos.logback.core.db.DriverManagerConnectionSource@4b5a4ad8 - Could not load JDBC driver class: com.microsoft.sqlserver.jdbc.SQLServerDriver java.lang.ClassNotFoundException: com.microsoft.sqlserver.jdbc.SQLServerDriver
INFO   | jvm 1    | 2019/10/01 14:41:03 | 	at java.lang.ClassNotFoundException: com.microsoft.sqlserver.jdbc.SQLServerDriver
INFO   | jvm 1    | 2019/10/01 14:41:03 | 	at 	at java.base/jdk.internal.loader.BuiltinClassLoader.loadClass(Unknown Source)
INFO   | jvm 1    | 2019/10/01 14:41:03 | 	at 	at java.base/jdk.internal.loader.ClassLoaders$AppClassLoader.loadClass(Unknown Source)
INFO   | jvm 1    | 2019/10/01 14:41:03 | 	at 	at java.base/java.lang.ClassLoader.loadClass(Unknown Source)
INFO   | jvm 1    | 2019/10/01 14:41:03 | 	at 	at java.base/java.lang.Class.forName0(Native Method)
INFO   | jvm 1    | 2019/10/01 14:41:03 | 	at 	at java.base/java.lang.Class.forName(Unknown Source)
INFO   | jvm 1    | 2019/10/01 14:41:03 | 	at 	at ch.qos.logback.core.db.DriverManagerConnectionSource.start(DriverManagerConnectionSource.java:37)
INFO   | jvm 1    | 2019/10/01 14:41:03 | 	at 	at ch.qos.logback.core.joran.action.NestedComplexPropertyIA.end(NestedComplexPropertyIA.java:161)
INFO   | jvm 1    | 2019/10/01 14:41:03 | 	at 	at ch.qos.logback.core.joran.spi.Interpreter.callEndAction(Interpreter.java:309)
INFO   | jvm 1    | 2019/10/01 14:41:03 | 	at 	at ch.qos.logback.core.joran.spi.Interpreter.endElement(Interpreter.java:193)
INFO   | jvm 1    | 2019/10/01 14:41:03 | 	at 	at ch.qos.logback.core.joran.spi.Interpreter.endElement(Interpreter.java:179)
INFO   | jvm 1    | 2019/10/01 14:41:03 | 	at 	at ch.qos.logback.core.joran.spi.EventPlayer.play(EventPlayer.java:62)
INFO   | jvm 1    | 2019/10/01 14:41:03 | 	at 	at ch.qos.logback.core.joran.GenericConfigurator.doConfigure(GenericConfigurator.java:155)
INFO   | jvm 1    | 2019/10/01 14:41:03 | 	at 	at ch.qos.logback.core.joran.GenericConfigurator.doConfigure(GenericConfigurator.java:142)
INFO   | jvm 1    | 2019/10/01 14:41:03 | 	at 	at ch.qos.logback.core.joran.GenericConfigurator.doConfigure(GenericConfigurator.java:103)
INFO   | jvm 1    | 2019/10/01 14:41:03 | 	at 	at ch.qos.logback.core.joran.GenericConfigurator.doConfigure(GenericConfigurator.java:53)
INFO   | jvm 1    | 2019/10/01 14:41:03 | 	at 	at ch.qos.logback.classic.util.ContextInitializer.configureByResource(ContextInitializer.java:75)
INFO   | jvm 1    | 2019/10/01 14:41:03 | 	at 	at ch.qos.logback.classic.util.ContextInitializer.autoConfig(ContextInitializer.java:150)
INFO   | jvm 1    | 2019/10/01 14:41:03 | 	at 	at org.slf4j.impl.StaticLoggerBinder.init(StaticLoggerBinder.java:84)
INFO   | jvm 1    | 2019/10/01 14:41:03 | 	at 	at org.slf4j.impl.StaticLoggerBinder.<clinit>(StaticLoggerBinder.java:55)
INFO   | jvm 1    | 2019/10/01 14:41:03 | 	at 	at org.slf4j.LoggerFactory.bind(LoggerFactory.java:150)
INFO   | jvm 1    | 2019/10/01 14:41:03 | 	at 	at org.slf4j.LoggerFactory.performInitialization(LoggerFactory.java:124)
INFO   | jvm 1    | 2019/10/01 14:41:03 | 	at 	at org.slf4j.LoggerFactory.getILoggerFactory(LoggerFactory.java:412)
INFO   | jvm 1    | 2019/10/01 14:41:03 | 	at 	at org.slf4j.LoggerFactory.getLogger(LoggerFactory.java:357)
INFO   | jvm 1    | 2019/10/01 14:41:03 | 	at 	at com.inductiveautomation.ignition.common.util.LoggerEx$Builder.build(LoggerEx.java:587)
INFO   | jvm 1    | 2019/10/01 14:41:03 | 	at 	at com.inductiveautomation.ignition.gateway.IgnitionGateway.getLogger(IgnitionGateway.java:3139)
INFO   | jvm 1    | 2019/10/01 14:41:03 | 	at 	at com.inductiveautomation.ignition.gateway.IgnitionGateway.<init>(IgnitionGateway.java:328)
INFO   | jvm 1    | 2019/10/01 14:41:03 | 	at 	at com.inductiveautomation.ignition.gateway.IgnitionGateway.main(IgnitionGateway.java:266)
INFO   | jvm 1    | 2019/10/01 14:41:03 | 	at 	at com.inductiveautomation.catapult.Catapult.main(Catapult.java:8)
INFO   | jvm 1    | 2019/10/01 14:41:03 | 	at 	at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
INFO   | jvm 1    | 2019/10/01 14:41:03 | 	at 	at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
INFO   | jvm 1    | 2019/10/01 14:41:03 | 	at 	at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
INFO   | jvm 1    | 2019/10/01 14:41:03 | 	at 	at java.base/java.lang.reflect.Method.invoke(Unknown Source)
INFO   | jvm 1    | 2019/10/01 14:41:03 | 	at 	at org.tanukisoftware.wrapper.WrapperSimpleApp.run(WrapperSimpleApp.java:349)
INFO   | jvm 1    | 2019/10/01 14:41:03 | 	at 	at java.base/java.lang.Thread.run(Unknown Source)
INFO   | jvm 1    | 2019/10/01 14:41:03 | 14:41:03,163 |-ERROR in ch.qos.logback.core.joran.spi.Interpreter@18:14 - RuntimeException in Action for tag [appender] java.lang.IllegalStateException: DBAppender cannot function if the JDBC driver does not support getGeneratedKeys method *and* without a specific SQL dialect
INFO   | jvm 1    | 2019/10/01 14:41:03 | 	at java.lang.IllegalStateException: DBAppender cannot function if the JDBC driver does not support getGeneratedKeys method *and* without a specific SQL dialect
INFO   | jvm 1    | 2019/10/01 14:41:03 | 	at 	at ch.qos.logback.core.db.DBAppenderBase.start(DBAppenderBase.java:60)
INFO   | jvm 1    | 2019/10/01 14:41:03 | 	at 	at ch.qos.logback.classic.db.DBAppender.start(DBAppender.java:92)
INFO   | jvm 1    | 2019/10/01 14:41:03 | 	at 	at ch.qos.logback.core.joran.action.AppenderAction.end(AppenderAction.java:90)
If anyone has ever had any success with pointing Ignition’s logback to a database, I would appreciate any advice you could give.
Unfortunately the JDBC drivers are not in the right ClassLoader to make what you’re attempting possible.
When I spoke with @Carl.Gould last week, I thought he said that it would be possible to do so by adding an Appender to logback, but perhaps I misunderstood him. I had been thinking that I would have to write my own logging scripts, and was very happy to hear that wouldn’t be necessary.
Is there a different Appender that I should be using, or is the entire exercise impossible?
If you are willing to experiment with the SDK, you could probably create an appender shim in a jar that is specified as an export, then have the rest of the module connect that shim to a normal Ignition DB connection.
{ Totally speculative on my part… }
You might get this appender to work if you put a copy of the JDBC driver jar into lib/core/gateway. Not sure if there would be adverse effects.
Thanks, I will try that. And if it doesn’t work, or if it causes any adverse effects I may try @pturmel’s approach.
I would expect it to break attempts to replace that driver via the gateway web interface. But likely otherwise work.
Looks like it works! And if we do ever need to update or replace that driver, we will deal with copying the new one over to lib/core/gateway as well.
Many thanks!
Another adverse effect: anything placed in lib/core/gateway will be removed by the installer if you upgrade Ignition, so you will need to account for that if you plan on upgrading.
