Logger in property change script
Hello,
I have this logger in the two first lines of my property change script:
logger = system.util.getLogger("myLogger")
logger.info("Hello, world.")
The log info should be displayed in the gateway each time the script is triggered but this doesn't happen. I even commented the rest of script out so that just these two lines remain, but still haven't seen anything when I trigger the script. Anything else in the script works.
It might help to tag your question as Vision or Perspective. Also, see Wiki - how to post code on this forum.
Additional information required:
  • Ignition edition and version.
  • On your Status → Diagnostics → Logs, what is your Min. Level setting?
Min. Level is ALL
Vision logs go to the local vision client log as @Transistor said. If you want those logs to go to the gateway logs, you'll need to create a message handler to do it. Send what you want to a gateway message handler, and log it from there.
