I'm looking to have a function were I can pass some arguments and it would print the name of the identifier and the value (in string) of it.
With the folwing code, I work perfect when I am in the script console.
But when I try to attach this into a script so I can call it from anywhere, the namespace globals() does not hold the identifier name.
Any idea ?
foo1 = 1
foo2 = "22"
foo3 = ['333']
def printTags(*args):
#Return the name of an identifier
def namestr(obj):
namespace = globals()
objName = [name for name in namespace if namespace[name] is obj]
return str(objName)
#iterate all the args to print the name of the identifier and the value
for i in range(0, len(args)):
logInfo = namestr(args[i]) + ": " + str(args[i])
system.util.getLogger("Log").warn(logInfo)
print (logInfo) #used for debugging
printTags(foo1, foo2, foo3)
