def post(Message, dataCall):
import system, datetime
now = datetime.datetime.now()
timeStamp = str(now)
nameDateFile = now.strftime("%Y%m%d")
filename = "c://Users//AJ//%s.txt"%(nameDateFile)
system.file.writeFile(filename, '\r\nIT\'S%s %s' %(timeStamp[0:23], str(Message)), 1)
#tagPath = str(event.tagPath)
#timestamp = newValue.timestamp
#system.tag.getTagValue(dataCall)
#currentTrack += " %s %s" % (timeStamp[0:23], str(Message))
#dataString.append([currentTrack])
#newdataset = system.dataset.toDataSet(["Current Track"], dataString)
system.tag.writeToTag(dataCall, '%s %s' %(timeStamp[0:23], str(Message)))
Here is the function within my module.
I have tried to create and use datasets but have found that they cannot be used as string tags in labels or list boxes.
here is my gateway script:
import app
app.Winchester.Logger.post(‘lgyter2’, ‘dataString’)
Can I make a loop in order to create places to hold my strings for my logger display?
Can I manipulate a large string tag to split it up and organize it as if it were a python list or string?
I would like to do this without a database.
If a dataset is the way to go, can someone explain to me how to use them…I’m a bit unclear as to how they would be useful without using a database.
