For some reason, when I try to switch users (via scripting) using my admin/password administrator credentials it does not work.
I have a classic security roles/users setup. 3 users: default, Operator, and admin. default is auto-signed in. I have a button that then prompts the user for username and password. This works flawlessly when I type in the Operator user’s credentials, but I’ve never gotten in as admin. I have verified that I have the username and password correct. These are the same credentials that I use to access the designer.
Do you have a required role in project properties? If so, does the admin user have that role? (Just having the Administrator role doesn’t magically grant any others.)
I found the issue. My bindings to the text field and password field were reversed, and my other user has identical user/password. Hence, why it worked for that user and not for admin.
