Login into a vision project?
I created a new vision project in the designer, but when I try to open the project in the vision client launcher, it asks for a login/password.
My personal login and password that I use in the gateway doesn't work (administrator).
Which login do I use then? Where do I add users for a certain project? Is it possible not to use a login page, so the project starts automatically without a user/password?
I think I have the same problem as this person :
Vision login help - Ignition - Inductive Automation Forum
But in there it doesn't say how to link a login to a vision project.
Found the problem :
In the designer I had do to the following :
Menu -> project -> project properties -> General -> change this one from "opcua module" to "default"
For posterity, this isn't exactly possible in Vision - you must always be logged in as someone. But you can use auto login to automatically log in as a "guest" user, with very limited access, potentially, and create your own login page. I wouldn't necessarily recommend it, but it's not unheard of.
I encounter this almost everywhere, and use it myself. Helped out by the longstanding IA project example that uses this approach to implement an "auto log out".
This is how I prefer do it as well.
I use the same approach too, autologin with guest credential that means simple read-only project and custom login popup for role based interaction.
