Login & Log out events
I would like to log the login and logout events of vision launcher.
I have added audit events to the project however i would like to have a separate table for it.
Any ideas to achieve?
Use triggers in your database on the regular audit table to copy the relevant rows to another table. There's no way for Ignition to do this for you. Or better, create a view in your database that applies the desired filter for you. If the audit event type is indexed properly, this should be a very quick alternative.
