Login on multiple devices at once - Perspective
Hi.
At our company we're implementing Ignition Perspective into our production. Till now we were using IFix from GE.
Current challenge to solve is how to login on multiple devices on same time.
Our workplace configuration:
  • 1 operator
  • 3 computer
  • 6 monitors
One person will work on 3 different computers on same time. On each computer we will connect 2 monitors. On every computer we will run 2 instances of Ignition Workspace, to get different session numbers, for better customization of workplace.
Does any one know hot to achive that login window will popup only on one of monitors and after username and passwords are typed in, the user will then be logged in on all 3 machines?
Is there any option to connect all 3 machines?
Is there any bypass with custom tag which will temporarily store username and password and fill form on other 2 computers?
Our goal is to simplify login procedure on workplace. I would like to avoid that operator need to input username and password multiple times.
Best Regards
You might have some luck on the same PC if you check the "remember me" checkbox when you log in (I've never got it working before...), but unfortunately you're out of luck trying to force a login via an IdP on the other machines; this simply isn't possible.
"It's the close elevator door button all over again"
