I am trying to connect to the Logix 5000 Emulate controller through OPC and after setting everything up I can see the tags but I cannot read or write from them. I have tried suggestions about DCOM settings and Uncheck the Use Async Operations in the ignition gateway OPC configuration. Still I cannot read or write.
I ran into the same issue. Were you be able to fix it?
